Number of digits
McIlhenny
at the moment I'm programming a procedure to import data from a general text file. There is just one little problem.
The data has the form
1399 1398.2 1397.4 ..
The stepwidth between the datapoints differs for different text files.
Now igor should calculate the difference between the first two datapoints, which should be 0.8 but Igor calculates 0.800049.
For other textfiles with a stepwidth of 0.05 igor calculates for example 0.0499992 or 0.0500031. This is a problem because when I want to scale my waves with this factor, the small deviations are adding up.
Is there a simple trick to solve this problem?
Best regards
or you could do:
(Last - first) * ( p / (numpnts-1)) + first
August 5, 2012 at 06:40 am - Permalink
August 5, 2012 at 07:02 am - Permalink
You can get better precision by loading the data into double-precision waves (/D flag of LoadWave operation). However it will still not be precise for all cases.
Single-precision floating point stores 24 binary bits of precision which is about 7 decimal digits. Double-precision floating point stored 53 binary bits which is about 15 decimal digits.
Here are some commands that illustrate this issue:
August 5, 2012 at 07:36 am - Permalink
