non negative least squares fitting in igor
lingxiaoabc
I have 3 set of measured values Y (wave0,wave1,wave2), the x value for these three sets are the same. Now I want to use two sets to fitting the third one using least squares fitting. The fitting function is very simple, which is " fit_wave_3 = A*wave0+B*wave1", A and B is the corresponding coefficient. How do I conduct that in igor?
Thank you very much.
Note that the assignment at the end uses round parens "()" to index wave0 and wave1. If the X scaling is set correctly on wave0 and wave1, and the values are evenly spaced in X, then if your data to fit doesn't exactly match the X ranges of wave0 and wave1, Igor will do linear interpolation to get intermediate values.
December 11, 2014 at 09:32 am - Permalink
Dear johnweeks,
there is no variable in that function.
December 12, 2014 at 04:44 am - Permalink
The wave pw contains the fitting coefficients, A and B in your case.
Perhaps you might explain whether you have gone through a basic fitting tutorial, for example for a simple linear regression fit? In particular, do you understand the use of coefficient waves to carry the fitting parameters?
Or perhaps you are wanting something else in your fitting function.
December 12, 2014 at 10:10 am - Permalink
