Multithreading wave read issues
I have a genetic algorithm program that works well, but I want to make it more efficient using multithreading and I rewrote the code to include multithreading, but I am running into problems reading waves when using multiple threads. To simplify what is going on I wrote a simpler program to demonstrate the problem. This simple code is supposed to pick two random waves (named "indX" where X is an integer) that exist and write them into temporary waves for further processing. Here is the code:
function BreedTest() variable tgID=ThreadGroupCreate(4) make /o/d/n=500 indA0,indA1,indA2,indA3,indB0,indB1,indB2,indb3 //create temp waves ThreadStart tgID,0, CrossoverThreadTest(indA0,indB0) ThreadStart tgID,1, CrossoverThreadTest(indA1,indB1) ThreadStart tgID,2, CrossoverThreadTest(indA2,indB2) ThreadStart tgID,3, CrossoverThreadTest(indA3,indB3) // Wait for all threads to finish before starting another batch of threads do Variable threadGroupStatus = ThreadGroupWait(tgID,100) while (threadGroupStatus != 0) end threadsafe function CrossoverThreadTest(indA,indB) wave indA,indB //temp waves for each thread string loopstr1,loopstr2 variable a,b a=floor(20+enoise(20)) b=floor(20+enoise(20)) print a print b loopstr1="ind"+num2str(a) loopstr2="ind"+num2str(b) Duplicate /o $loopstr1,indA Duplicate /o $loopstr2,indB end
when I run "crossoverthreadtest" by itself it functions perfectly. However, when I run it in the multithreading function ("breedtest") I get the error: "While executing Duplicate, the following error occurred: expected wave name".
It seems that when multithreading the program isn't able to see the "indX" waves, but doesn't have any issues when it is single thread. I am assuming this has something to do with how multithreading handles directories and waves but couldn't find anything in the help files. Does anyone know how to make this work?
Also, I am creating and passing separate temp files to each thread to be written too. Is there a more efficient method? Thanks.
Please execute the following command:
DisplayHelpTopic "Thread Data Environment"
Note this paragraph:
Your CrossoverThreadTest would only have access to the two waves passed as input parameters.
You might be able to pass a wave reference wave (Make/WAVE ...) to the threadsafe worker function, but as you've written the code even if the Duplicate worked the destination would be the private data folder of the preemptive thread but since you are not using ThreadGroupPutDF and ThreadGroupGetDFR I think you'll just otherwise lose that wave you create.
September 12, 2019 at 03:39 pm - Permalink
In reply to Please execute the following… by aclight
Aclight, Thank you for the information. Based on your comments it sounds like I should use ThreadGroupPutDF and ThreadGroupGetDFR. I have been looking at the Help topics on these and it isn't totally clear how to best implement it for my goal. Can you provide a code snippet showing how I can do this?
September 12, 2019 at 04:34 pm - Permalink
I'm not sure if you saw this topic or not, but it does have an example:
DisplayHelpTopic "Input/Output Queues"
I don't have a clear idea about what you're trying to do, since the example you gave doesn't run and doesn't make sense to me. For example, you're not actually using what would be the output waves of the worker function (the result of Duplicate) and your worker thread doesn't actually do any analysis.
I'm not sure that using the input/output queue is actually necessary in your situation.
September 12, 2019 at 04:48 pm - Permalink
In reply to Aclight, Thank you for the… by sleepingawake86
September 13, 2019 at 02:18 am - Permalink
Here is an example that I believe does pretty much the same thing as your original example, but uses the (arguably?) simpler MultiThread syntax. It also preserves the waves created by the Duplicate operation in the worker function.
September 13, 2019 at 09:10 am - Permalink
