I have a set of data in which the data are very closely spaced, I think something like 1000 data points. I was wondering if it's possible to plot the data using markers (so I don't have to use colors or dashed lines) but only use every 10th or 15th or 20th point. Is that possible without simply making a new wave? How do I do it?
Put the graph into Lines and markers mode and then in modify trace dialog, sparse markers will be an option.
mskip=n Puts a marker on only every nth data point in lines and markers mode (mode=4). Useful for displaying many data points when you want to identify the traces with markers. The maximum value for n is 32767.
If you want to do it in other modes then I think you have to do it manually by creating a new wave.
A great thing about Igor (and this forum for highlighting it) is there are often many ways to do one thing... so I'm always learning. My approach to this is to use a Macro (not written by me) to decimate a wave. It makes a copy, which is not what the OP wants to do, but I thought I'd post this as it might be useful to somebody.
May 30, 2015 at 03:30 pm - Permalink
Oh it IS in the GUI, it's called "sparse markers" I just hadn't tried "Lines and Markers" because I didn't want the line!
May 30, 2015 at 03:32 pm - Permalink
which allows to plot less but evenly spaced data points from a function / the command line.
HJ
May 31, 2015 at 02:10 am - Permalink
p.s. the name ReduceErrorBars is a bit misleading. It means reduce the number of points (not the size). It's useful for error waves.
May 31, 2015 at 11:49 am - Permalink
