Load a text line into a wave
mailfert
I'm trying to read a text file (not a tab delimited text file) with is like that:
# NEW_DATA: 64 data:
64:2: 1 1 1 (etc. there are 640values)
64:3: 102.96 233.25 333.45 (etc. there are 64 values)
64:4: 7.7255 78.39 83.966 (etc. there are 64 values)
64:6: 1.4 1.4 1.4 (etc. there are 64 values)
64:7: 0 0 0 (etc. there are 64 values)
64:8: 300 300 300 (etc. there are 64 values)
# NEW_DATA_SPT : 94 data:
94:2: 1 1 1 1 (etc. there are 94values)
94:3: 102.96 233.25 333.45 252.5 (etc. there are 94 values)
I cut the lines but the idea is that on each line there are a number of data to load which is not constant.
I would like to save these data into a wave.
I'm reading currently all lines, find the space characteres and read the data between two subsequent spaces and load them into a wave.
This is not as smart as I would like to do.
Is there a possibility to read and load data into a wave from a string containing data?
Thanks for your help.
Sébastien
No, but you can store the string in the clipboard using PutScrapText and load it from the clipboard using LoadWave "Clipboard". This is a kludge and overwrites the contents of the clipboard.
Alternatively you can write your data to a temporary file and load it from that. Here is an example:
http://www.igorexchange.com/node/1221
Alternately, you can read your data one line at a time and parse it. This is the least kludgy solution. It sounds like what you are already doing. Here is an example:
http://www.igorexchange.com/node/880
March 2, 2015 at 07:04 am - Permalink
You'll be using "Open", "FStatus", "FReadLine", and "Close" to handle each row of the text file individually in a while loop. FReadLine will be used to load a row of the text file into a string while you check FStatus to know if you've reached the end of the file (stop condition).
Now, for each row, after you parse the identifying info (ex. 64:4:) you'll be left with a space delimited list. Now, using "ItemsInList" you'll know how many data values exist in the row currently being evaluated. Using a for loop and "StringFromList" to extract the numbers one at a time and place them in a wave (that you have created to be the same number of points as reported by "ItemsInList") using the "str2num" conversion.
March 2, 2015 at 09:40 am - Permalink
OK, I had the good way to extract my data.
In Matlab, the loop is replaced by a simple sscanf call where all the data are stored in one vector automatically.
Thanks for your precious help.
Sébastien
March 4, 2015 at 12:29 am - Permalink
