listtotextwave with \000 as delimiter?
I've got a long string with \000 separating logical lines and want to put it into a 1D text wave.
listtotextwave doesn't seem to split on \000, I wind up with 2 rows which both appear empty while strlen shows the
string is 691 long. it's likely/certain that the string starts with a \000 (the first line is a null line).
I can work around this, but would like to know if listtotextwave works this was or it's something
i"m doing... (The string is coming from an XOP and I can see it's contents in the data browser).
Try this ...
January 2, 2025 at 08:56 am - Permalink
There is infinite number of list separators people picked based on whatever justification. Any generic code will be able to identify just few common ones. Custom code is necessary...
You are lucky, that at least the separator is fixed set of characters. Imagine that someone, in their "geniality", would use increasing order of the string numbers as separator: "\000this is first line\001this is second line\002and this is third one\004I hope this nonsense is clear\005".
January 2, 2025 at 08:00 pm - Permalink
thanks, that works, even without the RemoveListItem (the 0th is a null string and it comes out fine).
January 3, 2025 at 08:36 pm - Permalink
A bit of explanation...
Using null as a separator is going to cause lots of problems because it is the end-of-string character for C code text processing routines. Some if Igor's string functions have been specially coded to allow null bytes so that you can use a string to hold arbitrary binary bytes. That's why `strlen()` works in the presence of null bytes. But clearly `ListToTextWave` expects that a null byte marks the end of the string.
Glad JJWeimer's code worked for you! 'ReplaceString()' is another function that has been specially coded to allow null bytes, exactly for this sort of application.
January 6, 2025 at 12:02 pm - Permalink
