    Linear curve fitting to data in a 3D matrix
Requesting urgent help:
I have two 3D matrices. Dimensions are 23 x 19 x 5. One has mass concentrations. Second has corresponding peak areas. Essentially I have 23 x 19 locations for which I need to plot five-point calibration curves and calculate linear response factors i.e. slopes for mass versus peak area plots.
I've written the code but for some reason, it is not storing standard deviation values from the slope. Instead it just assigns it 0 for almost all 23 x 19. In some places it assigns values but they are completely random. The code is able to calculate slope for each of the 23 x 19 points but the values are incorrect. I'm not sure what mistake have I made. The slope and its standard deviation are supposed to be pretty small i.e. on the order of 1e-5 so I'm wondering if I'm not assigning a variable properly which is why the code is calculating incorrectly.
Here goes my code:
wave Cnumwave,DBE,Standardmass3D,Standardpeakarea3D,calibrationmasspoints //calibrationmasspoints=5, Cnumwave=23 and DBE[0]=19 killwaves /Z responsefactoravg,responsefactorstdv make/n=(numpnts(Cnumwave),DBE[0]+1)responsefactoravg make/n=(numpnts(Cnumwave),DBE[0]+1)responsefactorstdv variable i,j for (i=0;i<numpnts(Cnumwave);i+=1) for (j=0;j<=DBE[0];j+=1) make/n=(calibrationmasspoints[0])tempx make/n=(calibrationmasspoints[0])tempy tempx = nan tempy = nan tempy=Standardmass3D[i][j][r] tempx=Standardpeakarea3D[i][j][r] wave W_coef,W_sigma string graphName="calcurve" DoWindow/C $graphName killwaves/Z fit_tempy make/n=5 fit_tempy Display/N=graphName tempy vs tempx K0=0 CurveFit/H="10"/TBOX=768 line tempy /X=tempx /D fit_tempy=W_coef[0]+W_coef[1]*x responsefactoravg[i][j]=W_coef[1] responsefactorstdv[i][j]=W_sigma[1] Killgraphs() endfor endfor
Would really appreciate some advice!
A few thoughts in no specific order:
Why are you making and then immediately killing graphs inside the for-loop? A graph is not needed to generate W_coef and W_sigma from a curve fit.
Same question for fit_tempy. It seems to be extra effort for a wave (or graph) that goes through a make, fill, and kill process each step in a loop inside a loop.
Since tempx and tempy are 1-D waves, the proper form to generate them should likely be
(which may be the core problem)
I might recommend that you start this with a function call to do a linear curve fit on one (x, y) pair. Pull off a vector set from the mass and area matrixes and fit them in the function call. Convince yourself that you have coded the function to give the correct answers. Then, code to have that function as a Function/WAVE return the two fit values (w_coef, w_sigma) in a return wave. Finally, use that function inside a double loop.
September 3, 2019 at 06:06 am - Permalink
