Left and right axis with common zero
sven.kraft
I want to modify a graph with a left and a right y axis in a way that the zero points of both are in the same height, but the axes should still have different scales and not necessarily be Symmatric around zero.
The Data I'm using can look something like this:
•Make/N=100 DataL=gnoise(5)
•Make/N=100 DataR=gnoise(0.2)-0.2
•Display/L DataL
•AppendToGraph/R DataR
•Display/L DataL
Does Somebody know how to do this?
Thank you for your time,
sincerely,
Sven
This is close, I think:
Make/O/N=100 DataL=gnoise(5)
Make/O/N=100 DataR=gnoise(0.2)-0.2
Display/L /N=myGraph DataL
SetWindow myGraph, hook(alignZero)=AlignZeroHook
Function AlignZeroHook(s)
STRUCT WMWinHookStruct &s
Variable hookResult = 0
switch(s.eventCode)
case 8: // Modified
GetAxis/W=myGraph left
variable vLeftRange = V_max - V_min
Variable vLeftMin = V_min
GetAxis/W=myGraph right
variable vRightRange = V_max - V_min
Variable vRightMin = V_min
Variable vNewRightMin = vLeftMin * vRightRange / vLeftRange
SetAxis/W=myGraph right vNewRightMin, (vNewRightMin + vRightRange)
hookResult = 1
break
endswitch
return hookResult // 0 if nothing done, else 1
Hope this gives some ideas,
Kurt
February 28, 2019 at 08:19 am - Permalink
Hello Kurt,
I like the idea. The Problem here is that in your code the range is kept constant, thus a part of the Data is not visible anymore. So I Changed it a little bit:
switch(s.eventCode)
case 8: // Modified
//Go to automatic Scaling of right axis to get hole DataRange
SetAxis/W=$(s.WinName)/A right
DoUpdate;
GetAxis/Q /W=$(s.WinName) left
Variable LMax = V_max
Variable LMin = V_min
variable LRng = V_max - V_min
GetAxis/Q /W=$(s.WinName) right
variable RMax = V_max
Variable RMin = V_min
Variable RRng = V_max - V_min
//look whether the top or the lower range have to be extended
If(RMax/RRng>LMax/LRng)
Variable NewRMin=RMax-(RMax/LMax*LRng)
SetAxis/W=$(s.WinName) right NewRMin, *
Variable NewRMax=(RMin/LMin*LRng)+RMin
SetAxis/W=$(s.WinName) right *, NewRMax
hookResult = 1
break
endswitch
It now just get stuck if the left axis has no zero at all.
Thank you very much.
Sincerly,
Sven
March 1, 2019 at 02:38 am - Permalink
