JulianToDate problem
I want to convert a Modified Julian Date (MJD) & Time to seconds in normal IGOR siderial time.
I can convert MJD to Julian date but the JulianToDate function does not convert it to the format given in description. For example rather than the expected format for format 1 of dd/mm/year I get 6/7/2021 instead of 06/07/2021.
An additional difficulty is that there does not appear a way of extracting the time.
The great thing about the Igor forum is that invairably someone, somewhere has already done what your asking, and likely fogotten:
Check out this project which contains all kinds of functions to manipulate Julian, sidereal, ephemeris, and true solar time. Hopefully there is something useful in there for you.
October 29, 2021 at 01:30 pm - Permalink
Your are absolutely right cpr - the forum is jam-packed with experts who can answer questions on the most arcane or obscure nature, and I am glad you were able to respond.
I will need some explanation of your function. What is the format of the wave MJD? My data has the format for examp[le, 59396.023297 which is 2021-07-01 00:33:32 plus some frctional bits of seconds to a millisecond or so.
I am also unfamiliar with the function ParamIsDefault(pName) - how does it operate in the function?
I have not been able to get your project up and working because, as a private user, I have not yet purchased Version 9 yet. However, From what I can see there are some interesting functions there that are not dependant on version. It is quite dificult to find particular topics in the projects files and I had not come accross yours.
October 30, 2021 at 11:04 am - Permalink
Just some clarifications of the code used in cpr's function example:
- The function inputs are all variables (Type Variable), but since Igor 7 you can actually declare the type more precisely like in C: double = double-precision (64 bit) floating-point and int = 64-bit integer.
MDJ is not a wave but a single variable. If you want to convert the contents of a whole wave you would need to pass each entry through this function like so:
JD_TextWave = MJD2DateTime(MDJ_Wave[p])
- the function uses optional input parameters T and D, which are indicated by the square brackets. Yo can read more about this feature here:
DisplayHelpTopic "Optional Parameters"
This chapter also explains the function ParamIsDefault(), which is used to check whether an optional parameter ist set or not. In above function the parameters T and D control the output format of Secs2Time() and JulianToDate(). For example, if you call the function with T=3 you will get seconds in the output as well. If you don't set any of the optional parameters then T and D will both be 2.
October 31, 2021 at 03:13 am - Permalink
Hi Mike
MJD is as you would expect, days since 17 November 1858, as a variable. So if you execute the function the basic time and date are returned as a string - you could easily modify the function to get Igor DateTime:
There are optional parameters T and D which are the format arguments of JulianToDate and SecsToTtime - if you don't provide these the format is set to 24 hour time (option 2) and ISO day-date format (option 2), ParamIsDefault is checking if the optional parameters were passed. You could pass the optional parameters to get a different representation, e.g.:
I guess when I wrote it I wanted all the options available,but the default to be option 2 for both. Though I see there is no way to see fractional seconds so if you needed that you could use this modification:
Which when testing gives:
That Astronomical Algorithms project was written when testing the IP9 Beta so uses whatever new features there where - it could be ported back to IP8 easily but no further I think. Any function that has multiple return can be modified thusly, if you wish:
October 31, 2021 at 03:32 am - Permalink
If you use IP6 change any int,double etc to Variable - I tend to use double and int as its easier for me to type.
October 31, 2021 at 03:36 am - Permalink
In reply to Hi Mike MJD is as you would… by cpr
Hi cpr,
the modification does the job of returning the Time including seconds with decimals which is what I need. The issue with the way in which Julian2Date() works is still at odds with how the manual indicates: accordning to help, format 1 should give dd/mm/year but prints d/m/year. This appears to happen in my ip8 and your ip9. I want to get the string output to yyyymmdd format - this is not a big problem because, I note that options 3 provides spaces for omitted zeros in the format.
BTW my application is conversion of the dates and times of meteor events given in MJD to UT date and time.
This has been an interesting exercise for me and I have learnt IP features that are new to me. Great help and product.
October 31, 2021 at 05:19 am - Permalink
Ah, I see. Well where there's a will, there's a kluge:
Example:
October 31, 2021 at 05:46 am - Permalink
In reply to Ah, I see. Well where there… by cpr
Excellent - job done! Thanks again.
Mike
October 31, 2021 at 05:49 am - Permalink
