Assume that you are looking for a minimum value in a loop, you would like to initialize the check variable to the highest possible value, in order to prevent missing a value during the minimization.
I know that this is possible in JAVA, but is there a similar value in IGOR?
If you search for the minimum/maximum of values in a wave I' suggest to use WaveStats/M=0/Q instead.
It is much faster and better readable than any handcrafted loop.
Thanks for the hints - I am comparing the slopes of adjacent data points of a spectrum by windowing, so since I compare calculated values, I have to go for a loop - (I will post the snippet here for evaluation when I finish the code)
Anyhow, I often wondered whether it would make sense not using the built-in functions (like, Interpolate or Wave_Min()) too much for learning purposes - and in order to make code written in IGOR portable to other IDEs and other languages...
I personally felt one of the biggest "disadvantages" of IGOR to be that it is not possible to compile stand-alone programs...
You also might want to look into using do-while loops instead of for-loops, which are much easier to run indefinitely until you break the loop with a custom condition (e.g., just use while(1)).
June 10, 2014 at 09:14 am - Permalink
WaveStats /M=0/Q
instead.It is much faster and better readable than any handcrafted loop.
June 10, 2014 at 11:59 am - Permalink
June 10, 2014 at 01:43 pm - Permalink
Interpolate
orWave_Min()
) too much for learning purposes - and in order to make code written in IGOR portable to other IDEs and other languages...I personally felt one of the biggest "disadvantages" of IGOR to be that it is not possible to compile stand-alone programs...
June 10, 2014 at 02:18 pm - Permalink
while(1)
).June 10, 2014 at 06:24 pm - Permalink
