implementing DAQmx_Scan
I've been taking data by calling "fDAQmx_ReadChan()" repeatedly but I now need to take data at a much higher sampling rate.
So I began to look into using "DAQmx_Scan."
Looking at the documentation, I noticed there are a lot of flags and such.
But for the first iteration, I would be happy just to be able to store voltage data in a wave using "DAQmx_Scan."
My device name is "Dev1" and I am taking data through "channel 0." I believe that's pretty much all I need to implement, to my knowledge that is.
Function whassup()
make/O/N=10 Input0
string ScanString = "Input0, 0/DIFF, -0.5,0.5;"
DAQmx_Scan /DEV = "Dev1" WAVES=ScanString
print ScanString
Below is my feeble attempt to implement "DAQmx_Scan" (my best effort so far. At least I'm not getting an error with this one)
If I just want to measure whatever is getting fed into Analog Input channel 0, how would you go about doing it, using "DAQmx_Scan"?
I was looking for posts related to my question and found "https://www.wavemetrics.com/forum/general/nidaqmx-signal-averaging."
Apparently, the block of code below could work like an oscilloscope. I would like to know how this could be implemented, alternatively. (when i run the code, it says there are no grpahs or the specified graph does not exist)
Make/O/N=10000 Wave0
SetScale/P x, 0,0.000025, Wave0
SetAxis Left -5,5
DAQmx_Scan/DEV="dev4"/RPT WAVES="Wave0, 0"
Simply adding "display /K=1 Wave0 " below "SetAxis Left -5,5" returns an error "scanning already in progress"
Seems like that last little block should work in a basic way. What's going wrong? If you get an error, you get a large amount of fairly inscrutable error info from
print fDAQmx_ErrorString()The error info is hard to read but contains very useful information.
To get an oscilloscope-type display, see the /RPT and /RPTC flags.
September 19, 2018 at 04:57 pm - Permalink
