Igor Andy, You have to provide more details. Specifically, what is the syntax of the command that you are using? The error code suggests you were trying to save an image using QuickTime. If that is the case I recommend using a PNG file format. AG Log in or register to post comments April 29, 2013 at 01:58 pm - Permalink
hegedus Hi, This fails with "Size Check Failed" ImageSave/D=16/T="JPEG"/P=home/Q=1.00 Master as "Master.jpg" This works per your suggestion - Thank you. ImageSave/D=16/T="PNG"/P=home Master as "Master.png" Andy Log in or register to post comments April 29, 2013 at 03:23 pm - Permalink
AG
