ImageRegistration trouble
fjohann
I have some troubles with the ImageRegistration function. I would like to correlate two 2D images in two steps. First, run ImageRegistration to find the best fit by rotation and translation. In the second step I want to use the found M_RegOut image to run another ImageRegistration now skipping rotation but including skewing. The problem is, as far as I understand, that the M_RegOut from the first ImageRegistration will have severel NaN values (from where there is no overlap from the two images). Running ImageRegistration with a testwave having at least one NaN value will throw the error "One or more Parameters are inappropriate". Also, using a TestMask to exclude these points does not work.
Anyone any idea what I might do wrong?
Thanks.
Depending on your data you may be able to use other replacement values to possibly differentiate between the background and a boundary value.
May 19, 2015 at 09:57 am - Permalink
