Igor6 on MacOS 10.12 (Sierra) - Problem with Arial font
hrodstein
This affects both the English and Japanese versions of Igor6.
WORKAROUNDS
1. Purchase an upgrade to Igor7 which does not have this problem.
2. Use a different font.
3. Drag the Arial.ttf font file from /Library/Fonts to some other folder for safe keeping and restart your machine. Igor6 will use Geneva in place of Arial.
4. Drag the Arial.ttf font file from /Library/Fonts to your desktop and restart Igor. Igor will display blank text for Arial. Quit Igor and drag Arial.tff back into /Library/Fonts and restart your machine. Arial now works correctly in Igor. This workaround may not be reliable or durable, though I have not seen it to fail in limited testing.
Workaround #4 works for ASCII characters only. It does not work for non-ASCII characters (accented characters, math symbols, ...). For non-ASCII characters, you need to use workaround #1, #2 or #3.
5. Drag the Arial.ttf font file from /Library/Fonts to some other folder for safe keeping. Replace your Arial.ttf file in /Library/Fonts with an Arial.ttf file from C:\Windows\Fonts on a Windows machine and restart your machine. This workaround works for ASCII characters only. It does not work for non-ASCII characters (accented characters, math symbols, ...).
Workaround #5 works for ASCII characters only. It does not work for non-ASCII characters (accented characters, math symbols, ...). For non-ASCII characters, you need to use workaround #1, #2 or #3.
