Igor Pro 8 crashes with exception code 0xc0000005
I have been using Igor Pro 8 for 6 months now and since yesterday it started to crash without warning. Igor Pro 8 just closes and gives no error messages. The computer is running Windows 10 64-bit. Looking in windows event logs, we found the following reports from the latest crash. Does anyone know what causes these crashes and how to fix them? Thank you.
Logged: 4/14/2023 11:28:55 AM
Log Name: Application
Source: .NET Runtime
Application: Igor64.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 00007FF7598799F0
Source: Application Error
Faulting application name: Igor64.exe, version: 8.0.4.2, time stamp: 0x5dd3f8e8
Faulting module name: Igor64.exe, version: 8.0.4.2, time stamp: 0x5dd3f8e8
Exception code: 0xc0000005
Fault offset: 0x0000000006eb99f0
Faulting process id: 0x3500
Faulting application start time: 0x01d96e4dc3b2d95e
Faulting application path: C:\Program Files\WaveMetrics\Igor Pro 8 Folder\IgorBinaries_x64\Igor64.exe
Faulting module path: C:\Program Files\WaveMetrics\Igor Pro 8 Folder\IgorBinaries_x64\Igor64.exe
Report Id: 5abfa6d7-3410-4e37-8286-3d9bf175fd9a
Faulting package full name:
Faulting package-relative application ID:
Please execute the following command on Igor's command line:
DisplayHelpTopic "Crashes On Windows"
Then follow the instructions there. The exception cited in your report is a simple crash due to Igor accessing memory that it shouldn't access, but there is no way to determine the cause of the crash from that exception code. Greater than 90% of crashes are caused by that same code.
April 14, 2023 at 09:38 am - Permalink
