This may be a simple question but I can note how to do that. Is it possible to set a default working folder such that whenever I load data or saving experiment, I will be inside that folder automatically instead of starting all over from the root directory?
Your AfterFileOpenHook function would need to verify that the file being opened is an experiment file (kind parameter is 1 or 2) and that the data folder exists (DataFolderExists function).
In your case the command would be something like:
SetDataFolder root:MyDataFolder
To do it in all experiments you can create a hook function:
November 29, 2012 at 08:52 am - Permalink
