How can I introduce my button ?
I want to use button for running my code, I mean I write some code to appear some buttons and I like after press my button, it do rest of my code.
If you please check my code in attachment, you will be see I have my button which called "Calculate number of atoms" but I can not introduce it correctly and when I press it I see error.
My aim is: after press this button, it do rest of the my code
Thanks so much
You will have better success if you let Igor's dialogs create panel code for you to start, and then you can modify it to suit your purposes. I often add controls to a new panel, then save the window recreation macro (Window->Control->Window Control... and check "Save macro"), and then make a function out of it like the example below.
The
Window Panel0() : control panel
part should be just:Window Panel0() : Panel
, though quickly you will learn that a good name for a panel is useful when modifying controls or just bring the window to the front, so I'd suggest code like this:--Jim Prouty
February 10, 2014 at 09:55 am - Permalink
I am newbie and I need work a little more.
I use your suggestion and it is great but some times it shows this error (while executing removecontour, the following error occurred:Expected the name of a contour matrix or z wave in the top graph), I want to know is correlate in my igor or maybe because of my data loding from another code?
By the way, If I want to add another button, should I do same process?
Thanks
February 11, 2014 at 08:03 am - Permalink
Button button0,pos={60,110},size={161,35},proc=ROIProc,title="Integrate ROI"
Button button1,pos={60,65},size={161,35},proc=buttonproc,title="Calculate number of atoms"
Endmacro
Function ButtonProc(ctrlName) : ButtonControl
String ctrlName
string ctrlname0
variable nc=2
variable ic, nt=0
February 11, 2014 at 02:56 pm - Permalink
February 11, 2014 at 03:49 pm - Permalink
With your guide, I can do for one of the my button and as you see in my code , I put my calculate routine only for this button and it is work very well.
I have not any idea about, where I can put the calculation for another button,POPUMENU and ... or how can Igor knows them?
Thanks for your time Jim
February 11, 2014 at 05:44 pm - Permalink
but you haven't written a function or Proc named ROIProc.
February 12, 2014 at 09:10 am - Permalink
What about the popupmenu? I like when I switch between the value of the popumenu, its action change.
For it, do I need to write Function also? How can it understand this switch?
Sorry for a lot of questions
February 12, 2014 at 03:49 pm - Permalink
Use the control dialog to create the action function, even if you leave it blank.
Then find it in the Procedure window and fill it in.
Read the docs on the the PopupMenu value keyword; it is a little tricky.
February 12, 2014 at 09:20 pm - Permalink
January 17, 2017 at 06:11 am - Permalink
displayhelptopic "button"
will list in the parameters section:
pos={left,top } Sets the position of the button in pixels.
HJ
January 17, 2017 at 01:08 pm - Permalink
