Horizontal category plot/bar chart?
I'd also like to add that having an option to add individual datapoints to each bar would be very helpful (i.e. if you're plotting averages and want to plot the individual values that make up each average overlayed on the bar chart). At the moment I do it manually be adding a normal plot onto category plot and but that's quite painful and time consuming. Is there no easier way to do this currently?
/VERT
flag from thedisplay
command.Maybe you also want to have a look at
DisplayHelpTopic "Category Plots"
For your second issue I have no proper solution present...
HJ
March 10, 2015 at 04:50 am - Permalink
I just looked in the manual - in the index under 'category plot' there is an item called 'horizontal bars'. Following this link takes you to a page which says you create a normal vertical bar plot and then select the Swap XY checkbox in the Modify Graph dialog (Graph menu).
Hope this helps.
March 10, 2015 at 04:55 am - Permalink
March 10, 2015 at 05:34 am - Permalink
