Help referencing strconstant
sjr51
I'm trying to reference a strconstant and can't get it to work. I must be missing something simple. Outside of my function I have:
StrConstant SRON_1 = "0x4477aa;" StrConstant SRON_2 = "0x4477aa; 0xcc6677;" StrConstant SRON_3 = "0x4477aa; 0xddcc77; 0xcc6677;" StrConstant SRON_4 = "0x4477aa; 0x117733; 0xddcc77; 0xcc6677;" //snip
and so on.
In my function I want to pick one of these palette lists to use and then go on to pick and calculate a colour.
//snip String palettepick= "SRON_" + num2str(cond) SVAR pal= palettepick //then in a loop lower down color=str2num(StringFromList(i-1,pal))
I then calculate the 16 bit RGB from the hex color. The code all runs except that it just takes the last StrConstant in the list, i.e. even though cond=2 it will take SRON_12. So the
seems to not work the way I think it should. I've searched the help etc. and couldn't find a solution. Is it possible to determine this programmatically or do StrConstants have to be addressed by the user?
Something like this will work...
August 20, 2015 at 06:09 am - Permalink
August 20, 2015 at 06:23 am - Permalink
