Having Problems with AppendLayoutObject
The problem I am having is the AppendlayoutObject command does not seem to recognize the names of the graph. For example, if the graphs w
Proc MakeGraph() variable num = numpnts(Hold_Names) //string wave that holds the names of the various waves to be graphed Do Graph(Hold_Names[num-1]) num -= 1 While (num > 0) End Function Graph(name) string name string name1 = name + "_Phase Error" NewLayout/N=$name/Hide=0 display/Hide=0 $(name)[][0] as name1 AppendLayoutObject/W=$name graph $name1 End
What happens when I run the above code is the graph appended to the specified layout is a blank box. The appendlayoutobject command seems to only recognize the graph by the names graph0, graph1 and so on and not by the names I have given it. Eg, Data_A_Phase Error
Read this to understand the difference between a name and a title:
DisplayHelpTopic "Window Names and Titles"
July 5, 2016 at 09:23 am - Permalink
