Gizmo and customized surface cuts
thomas_braun
I want to create a Gizmo with some fancy slices.
My starting point is the Gizmo slicer Panel. It creates slices at planes in the X,Y,Z direction.
Now I would like to define these surface planes more freely. For example I want them to hold data summed over multiple indizes, or even all planes in a direction.
For the z-direction I've succeeded by using a Surface with a Matrix wave as source, define my MxN surface wave with constant entries, and use "Color from wave" from a custom color table.
// create necessary waves Function doStuff0() Wave data // 3D data to visualize Make/O/D/N=(DimSize(data,0),DimSize(data,1)) cut0 cut0 = DimOffset(data,2) CopyScales data, cut0 Duplicate/O cut0, sum0, col0 Redimension/N=(-1,-1,4) col0 variable sl // sum all layers variable i, j, k for(i=0; i < DimSize(data,0); i+=1) for(j=0; j < DimSize(data,1); j+=1) sl = 0 for(k=0; k < DimSize(data,2); k+=1) sl += data[i][j][k] endfor sum0[i][j] = sl endfor endfor // color table magic colortab2wave Rainbow Wave m_colors Redimension/D/N=(-1,4) m_colors m_colors[][3] = 0 // alpha m_colors /=65535 wavestats/Q sum0 SetScale/I x, V_min, V_max, "", m_colors col0 = m_colors(sum0[p][q])[r] End ///.. relevant gizmo code AppendToGizmo Surface=root:cut0,name=proj0 ModifyGizmo ModifyObject=proj0 property={ surfaceColorType,3} ModifyGizmo ModifyObject=proj0 property={ srcMode,0} ModifyGizmo ModifyObject=proj0 property={ surfaceColorWave,root:col0} //...
But how can I do that for the other dimensions? I've tried parametric and quad waves, but these don't allow setting a custom color wave in the way it is done with the Matrix wave as source.
I could translate and rotate my surface defined with Matrix wave as source. But this gets quite involved, as I have to keep track of wave scaling also. And speaking of complicated I'm not sure I want to involve textures either.
Any ideas?
Thanks
Thomas
An easy way to accomplish what you want is to create a parametric wave for the desired plane and assign to it a color wave that represents your data. This is how the image on the left is created. The parametric wave happens to define a sphere and the data are sampled along a sphere in an MRI of a brain.
Obviously there are other ways to accomplish the same thing, e.g., using textures, but I really think the other approaches are far more complicated than using a parametric surface. Feel free to email me a sample experiment if you need more specific help.
March 26, 2014 at 04:55 pm - Permalink
