Getting Igor version 4 to trigger trains
Hi, I am running Igor version 4.01 and am using it to control a National Instruments data acquisition system (E-series board). I would like to get Igor to generate a pattern that can be either interval-based or event-based. Basically, the pattern is a train of pulses, with the inter-pulse intervals varying across time in a Poisson manner. Does anyone have a procedure file or whatever program that would enable me to specify in Igor 4 such kinds of stimulus patterns? I would also appreciate any suggestions or tips on how to modify code in Igor 4 to do that as well. Thanks.
Use the waveform generator and fill a wave with the pulse pattern you want, then generate a waveform using that pattern. If you can't do that, please provide some more details.
That's a very old version of Igor :)
Here is a crude function to get you started in generating the Poisson pulse pattern. It assumes that the probability of having a pulse in a given wave deltax, lambda*deltax, is <<1. As well as creating the Poisson pulse wave, the function also returns, as a rough check, the trial's estimate of the arrival rate (lambda) from the number of trial pulses.
function poisson(lambda, npts, dx)  // lambda=probability per unit time; npts=numpnts(wave0)
    variable lambda, npts, dx   // dx=wave deltax scaling
    make/O/N=(npts) wave0
    setscale/P x, 0, dx,"" wave0
    wave0   = abs(enoise(1))<(lambda*dx) ? 1 : 0
    return sum(wave0)/(npts*dx)
From this you should be able to generate the DAQ wave you need. If you need wider output pulses, be careful that your lambda is small enough so they have a small probability of overlapping. If Igor 4 does not have the conditional assignment syntax, you can make your own (if, else) equivalent.
