Filled colour in contour plot
Hi Igor Wave metrics members
I want to make filled contour plot for my x,y,z data. I followed previous topic
"http://www.igorexchange.com/node/2366"
but I couldnt get filled contour. Maybe I missed about appending the image plot and my contour plot.
Here I attached my contour plot.
my data is in x,y,z format and have 20 rows each.
Please help me to solve this issue.
Thanks
Add the following to the procedure window.
#include <appendimagetocontour>
Now, "Append Image or Fill Between Contours" will appear as the last item in the Graph menu list.
[quote=proland]Add the following to the procedure window.
Now, "Append Image or Fill Between Contours" will appear as the last item in the Graph menu list.[/quote]
When I copy past this command I get syntax error. that means letters should be separated? plus which image I should append to the contour. I didnt plot anything to append.
Look in your Packages submenus.
Graph->Packages->Fill Between Contours...
I upgraded my igor. and I used package. Tank you very much.
But at the corner of the image is still white and is there a short cut to remove numbers from contour.
best regards
[quote=thabes]I upgraded my igor. and I used package. Tank you very much.
But at the corner of the image is still white[/quote]
The region outside of your contour's boundary is interpreted as being the smallest z value (no extrapolation is done).
[quote=thabes]and is there a short cut to remove numbers from contour.[/quote]
Remove labels by using the Graph->Modify Contour dialog, and set Labels to None.
[quote=JimProuty]Look in your Packages submenus.
Software Engineer, WaveMetrics, Inc.[/quote]
The best answer!
