Fill closed plot on graph?
I have a plot (close loop) which I'd like to fill with either a solid color or a pattern. Using the menu commands, which show up as:
ModifyGraph hbFill(y2a)=49,plusRGB(y2a)=(17476,17476,17476)
ModifyGraph mode(y2a)=7
it splatters the fill across the borders. See attached screen shot, with the plot shown in red.
Is there a way to fill just the red plot?
DN
It looks like you're using Fill To Zero mode. I think you need Fill To Next. For help, execute this:
DisplayHelpTopic "Grouping, Stacking and Adding Modes"
If you can't get it to work, if feasible, save your graph to a .pxp file (File->Save Graph Copy) and attach the resulting file to a post here so we can play with it.
Also specify what OS and what version of Igor you are using in case there is a bug involved.
I've been exploring the various modes and have not been able to get it to do what I want. So I have attached the pxp and csv data file.
I also tried splitting the closed loop into two curves, but no luck.
DN
mw_plot.zip (18.24 KB)
I misunderstood. The fill modes for graph traces will not help you because they fill to Y=0 or to another trace.
You want a filled polygon. For this you need to use drawing tools. Here are the commands I used:
// Remove y2a trace - we will use drawing tools instead
RemoveFromGraph y2a
// Direct drawing to the User Front layer
// If you do this programmatically, you may want to use ProgFront instead
SetDrawLayer UserFront
// Use axis coordinates for drawing elements
SetDrawEnv xcoord=bottom,ycoord=left
// Set current line color to red
SetDrawEnv linefgc=(65535,0,0)
// Set current foreground fill color to gray
SetDrawEnv fillfgc=(43690,43690,43690)
// Draw polygon using x2a and y2a coordinates
DrawPoly x2a[0],y2a[0],1,1,x2a,y2a
Note that I used a gray color fill instead of a pattern. You can change this by showing the drawing tools, double-clicking the polygon, and using the resulting dialog.
For information on the DrawPoly operation, execute this:
DisplayHelpTopic "DrawPoly"
For information on drawing layers:
DisplayHelpTopic "Drawing Layers"
For general information on drawing:
DisplayHelpTopic "Drawing"
Thanks. I had in the interim used the drawing tools, but manually. It's great to know how to automate that.
