Usually, waves with many points are very big. If you don't see any obvious waves with a large number of points, then such data might be 'out of sight' in the Packages folder etc. If you have Igor 9, you can see the size of each object by right-clicking the top column inside the Data Browser's folder view and activating the 'Size' option.
April 13, 2022 at 08:21 am - Permalink
In reply to Usually, waves with many… by chozo
Thank you, this works also in Igor8. I found the monster in a subfolder...
April 13, 2022 at 09:12 am - Permalink
