I'm having trouble exporting a graphic as 16 bit. I'm using SavePICT with /D (whole bit is SavePICT/E=-6/RES=200/D=16). However the file that pumps out always seems to be 8bit (opened with other program). I've tried using D=1,8,16,24, and 32 and the size of the file is always the same after export, shouldn't it get larger with increasing bit size?
I've tried in both IP6(.37) and IP7. I switched to SavePICT/E=-7/Res200/D=16. No Difference though. It always saves the graphic as 8bit. I Switched to ImageSave. That worked.
Thanks for the details on jpg. I didn't know that.
/E=-6 is a JPEG file. JPEG files are not supported in any bit depth other than 8-bit/sample. If you need 16-bit output consider using TIFF format.
October 24, 2016 at 04:00 pm - Permalink
Clayton
October 24, 2016 at 08:24 pm - Permalink
