exporting data in igor to excel
Hi, all
I'm a really beginner for igor, so I'd like to ask you simple question. I hope you guys give me useful answer.
I tried to copy my data (numerical) to excel worksheet and it worked, but the problem was that it didn't work when I used a function such as "average". I set up the cell to number. I think there's sth different the way how the two softwares handle data. Excel may not regard the copied data as number.
One more thing, on igor, I cannot use simple statistics such as "average", "stdev", etc. ?
Thanks for your help.
Puhaha
You might look at these code snippets for some examples of translating Excel to Igor Pro commands.
July 29, 2011 at 04:30 am - Permalink
Thank you so much ! It would be really usefull for me.
These codes are used to translate data from excel to igor, but what about from igor to excel ? Is it possible?
July 29, 2011 at 05:38 am - Permalink
As for for generating averages and stdev etc you will need to use the wavestats command. The command help gives a really good break down of how the syntax works, just look under help, command help and scroll down to wavestats.
Hope this helps,
August 11, 2011 at 09:34 am - Permalink
I strongly recommend looking at the Getting Started help. You can get to it easily by selecting Help->Getting Started. Go through at least the first half of the Guided Tour (which is part of Getting Started). Igor works quite differently than other applications, and the Guided Tour will introduce you to some of the differences.
August 11, 2011 at 04:52 pm - Permalink
