Error: trace is not on graph
awash
Hello! I am currently making a code in Igor that involves using cursors. I am not very familiar with them so I am in need of assistance. I am trying to use a cursor but I keep having the error: trace is not on graph. I have tried following the Igor cursor examples for help with this issue but to no avail. Any help would be appreciated.
// find x_value for corresponding y-half // AppendToGraph selection_fit string tname = NameOfWave(selection_fit) Cursor/P A tname 0 Print CsrXWaveRef(A)[100]
For context, selection_fit is the name of the wave that is created from a curve fitting.
Cursor takes a trace name, not a string containing a trace name. So, with you command, it is looking for a trace named tname.
Use selection_fit instead of tname in the Cursor command.
You could use this:
Cursor/P A $tname 0 // $ converts a string containing a name to a name
but it is not necessary in this case.
June 24, 2022 at 12:33 pm - Permalink
Thank you so much for your help! This makes a lot of sense
June 27, 2022 at 06:48 am - Permalink
