Error in FFT example from manual. "Complex wave used in real expression"
The Manual gives the following example in II-5: Waves
Make/O/N=1024 wave0 SetScale x 0,1,"s", wave0 wave0 = sin(2*PI*x) + sin(6*PI*x)/3 + sin(10*PI*X)/5 + sin(14*PI*x)/7 Display wave0 as "Time Domain" // Do FFT Duplicate/O wave0, cwave0 FFT cwave0 cwave0 /= 512; cwave0[0] /= 2 Display cwave0 as "Frequency Domain";SetAxis bottom, 0, 25 // Calcualate magnitude and phase Make/O/N=513 mag0, phase0, power0 CopyScales cwave0, mag0, phase0, power0 mag0 = real(r2polar(cwave0)) phase0 = imag(r2polar(cwave0)) phase0 *= 180/PI Display mag0 as "Magnitude and Phase"; AppendToGraph/R phase0 SetAxis bottom, 0, 25 Label left, "Magnitude";Label right, "Phase" // Calculate power spectrum power0 = magsqr(cwave0) Display power0 as "Power Sepctrum";SetAxis bottom, 0, 25
But the line "cwave /= 512; cwave0[0] /= 2" gives an error. "Complex wave used in a real expression." What would be the proper way to renormalize the amplitude of cwave0? Sort of discouraging that the manual wouldn't do it correctly.
The code was designed to be run from a Macro or command line many years ago.
Putting the code into a function wasn't tried after Igor added more stringent checking of wave reference types.
That checking is placated by using a WAVE/C wave reference on the FFT result:
October 7, 2020 at 03:28 pm - Permalink
This version runs in both a function and in a macro (macros don't permit or need WAVE statements):
October 7, 2020 at 03:50 pm - Permalink
