Dividing all waves in a folder by a value
Hi guys,
I have a problem, which might be very easy to solve. I have a folder with waves and I want to divide all waves by the factor 1000 using the following function:
Function NormalizeAll()
Variable n=ItemsInList(wavelist("*",";",""))
Variable i
	For (i=0; i<=n; i+=1)
		$(StringfromList(i,wavelist("*",";","")))=$(StringfromList(i,wavelist("*",";","")))/1000
   EndFor
The error is: "Can't use $ in this way in a function". I am confused, because I have used the $-trick in a function before. If I put the line in the for loop in the commander for a specific value of i, it works. Thank you for your help!
You have to declare the wave first
Variable i
        Wave MyWave=$(StringfromList(i,wavelist("*",";","")))
        MyWave=MyWave/1000
   EndFor
For your curiosity here is another way of accomplishing the same thing with different commands
Function MyFunction()
    //  The datafolder to look for waves in
    DFREF MyFolder=root:MyFolder
    //  Checks that the datafolder exists
    If ((DataFolderRefStatus(MyFolder)!=0)
        //  Counts the number of waves in the folder
        //  (If you have non-numeric waves in the folder you will have to add additional checks for that)
        Variable n=CountObjectsDFR(MyFolder, 1)
        //  Creates a list of all waves in the folder
        Make/FREE/O/WAVE/N=(n) AllWaves=WaveRefIndexedDFR(MyFolder, p)
        //  Multithreads dividing the waves by 1000
        MultiThread AllWaves[]=DoStuffToWave(AllWaves[p])
ThreadSafe Function/WAVE DoStuffToWave(MyWave)
//  Divides the waves by 1000. Uses FastOP for speed increase
Wave MyWave
    FastOP MyWave=(1/1000)*MyWave
    Return MyWave
Depending on how often you need the command, don't forget the ability to execute a command in the data browser.
Select all the waves of interest and then in the execute command dialog:
%s /=1000
