Curve fitting subrange of data
epiphenom
I have written a function that does what I want but have ran into difficulties with the curve fitting part of the script.
I would like to fit to the subrange : more_than_zero[index] and max_current[index] ---- how do I properly format this in the CurveFit function?
for(index=0; index<numXYPairs; index+=1) String xWaveName = StringFromList(index, new_curr) Wave xWave = $xWaveName String yWaveName = StringFromList(index, new_cell) Wave yWave = $yWaveName wave cell_num //wave More_than_zero //wave max_current cell_num[index] =yWave[index] //FitAndGraphXYPair(xWave, yWave) Display yWave vs xWave ModifyGraph mode=3,marker=19,rgb=(0,0,65535) // Round blue markers DoUpdate // get x-range that will be used to fit the slope Findlevel /Edge=1 /Q /P yWave, 0 ; More_than_zero[index] = V_levelX+1 WaveStats /M=2 /Q /R = (0,) yWave; max_current[index]= pnt2x(xWave,V_maxloc) /// fitting to the whole x-range , set /X=xWave CurveFit /TBOX=256 line yWave /X= xWave[(More_than_zero[index]),(max_current[index])] /D wave w_coef wave w_sigma wave cell_num slope_fi[index] = w_coef[index] error_slope_fi[index]= w_sigma[index]
CurveFit /TBOX=256 line yWave[More_than_zero[index], max_current[index]] /X= xWave /D
If you want different subranges (such as might occur if you want the Y data to be one column of a multi-column wave, and the X data from another column) then you need to specify a subrange on each wave.
February 6, 2017 at 04:05 pm - Permalink
February 6, 2017 at 05:31 pm - Permalink
