Cubic and linear baseline
Just a question.....I have a single peak with some background and i tried 2 sets of fitting. First case, i used ''linear'' baseline and i did the fitting and the result was ok. I then tried to do it using ''cubic'' and it worked much better which i expected since the background does not look very linear. Just out f curiosity, i then tried to set to zero the K2 and K3 terms of the cubic function, essentially leaving myself with a linear function. I just wanted to see if the software will give me similar coefficients as in my initial try when i used ''linear'' baseline. However, the coefficients were very different but the goodness of fit (chi square) was identical to the one i obtained when i initially used the option of ''linear'' baseline. Any ideas for that? I hope my message is not very confusing. Thanks a lot
Hard to tell without displayed data and fits...
From the manual (Overview of Curve Fitting):
HJ
September 5, 2017 at 07:18 am - Permalink
September 11, 2017 at 01:34 pm - Permalink
