It is not obvious exactly what you need. If you know how to compute the cross correlation between any two waves and you know how to extract columns of a matrix then the answer is straightforward. If you are using IP7 you could correlate col i with col j or matrixWave with syntax like:
Here opt is 0 or 4 depending on your choice of correlation.
Once you are happy with the cross correlation you can combine the above with
I hope this helps,
February 17, 2017 at 09:50 am - Permalink
