ControlInfo / FindValue don't generate variables
Hey!
I tried to make a temporary function to get all checkboxes's names in a window and use them with ControlInfo to get their Titles, so I could use it to change a wave containing this information. The problem is that ControlInfo don't create any variables when executing inside the For loop, neither FindValue. I tested just these commands in the command window, works fine.
It ends up in an error because S_title is empty.
Why these functions don't generate the variables inside the loop? Code bellow:
Function aux() variable controlnumber variable windex variable i string controllist string controltitle string controlname wave/T wPDG = root:VarList:wPDG controllist = ControlNameList("PreDefinedGroups") for(i=0;ItemsInList(controllist)>i;i+=1) if(StringMatch(StringFromList(i,controllist),"group*")) continue else controlname = StringFromList(i,controllist) ControlInfo/W=PreDefinedGroups controlname FindValue/TEXT=S_title/TXOP=1 wPDG windex = V_row wPDG[windex][2] = controlname wPDG[i][3] = "0" endif endfor End
ControlInfo/W=PreDefinedGroups $controlname
ControlInfo expects a "name" of the control, not a string. You need the "$" in this case.
March 10, 2020 at 07:19 am - Permalink
