Contraints of multiple variables.
I am trying to curve fit my FCS data to a user defined formula Sum(Ai/((1+4*Di*t/w^2)*sqrt(1+4*Di*t/z^2)))
So basically Ai is 3 different variables A1,A2,A3 which represent the percentage of a specific component (Free dye, dye+enzyme, dye+enzyme+DNA) . Is there a way to set their initial guess and to also have A1+A2+A3=1?
Igor 6.04
OS X build
Michael Meadows
m.meadows wrote: I am trying to curve fit my FCS data to a user defined formula Sum(Ai/((1+4*Di*t/w^2)*sqrt(1+4*Di*t/z^2)))
Igor 6.04
OS X build
Michael Meadows
Rather than having A1, A2 and A3 all as fit coefficients, you should fit A1 and A2 and then use 1-(A1+A2) instead of A3.
The alternative would be to use two constraint expressions. Say K0 is A1, K1 is A2, and K3 is A3:
K0+K1+K2>0
K0+K1+K2<0
That involves making a text wave with those two lines and then selecting that text wave in the Curve Fitting dialog. But really my first answer is preferable- you don't have three coefficients, you really only have two because of the constraint on the sum. Fitting will work better if you do it that way.
