    Comparison of data to arbitrary waveforms?
Is there a simple way to compare one waveform against a set of others? I would like the output to be 1) a factor expressing how much the "reference" waveform has to be scaled to best fit the "test" waveform, and 2) a measure of how good the fit is. I guess I'm looking for a curve fit operation where the only free parameter is the amplitude of the reference waveform.
I could probably fit the reference waveform with a function and then fit that function to all of the test waveforms, but would prefer a direct comparison. Does such a method already exist?
Any help would be much appreciated!!
Mike
Now use the Analysis:Curve Fitting menu with Function=ScaleFit, Y Data=TestWave, and X Data=_calculated_. Set the Coefficients:Coefficient Wave as _default_ and the coefficient w[0] as 1 to start the curve fit.
May 19, 2008 at 10:25 am - Permalink
