Column Names from Header in delimited text file
I d like to read a .txt file containing a header where lines start by a "# ", followed by 5 space delimited column of numbers.
The last line of the header contains the names of the columns starting with a "# " and space delimited.
Looking at earlier posts on the forum I got
Function ReadHeaderAndData(pathName, fileName, extension) String pathName // Name of symbolic path or "" to display dialog. String fileName // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path. String extension // e.g., ".dat" for .dat files. "????" for all files. setdatafolder root: Variable refNum // Possibly display Open File dialog. if ((strlen(pathName)==0) || (strlen(fileName)==0)) Open /D /R /P=$pathName /T=(extension) refNum as fileName fileName = S_fileName // S_fileName is set by Open/D if (strlen(fileName) == 0) // User cancelled? return -1 endif // fileName is now a full path to the file. endif // Read the header lines Open /P=$pathName /R refNum as fileName // Read header here using FReadLine string buffer string/g header string lastline variable numline=0,Cond=1 do FReadLine refNum, buffer if(strsearch(buffer,"#",0)==0) header+=buffer Numline+=1 LastLine=buffer else Cond=0 endif while (Cond==1) Close refNum // print header Variable linesToSkip = Numline Variable linesToLoad = 0 // Number of lines to load or 0 for auto (load all lines). Variable columnsToSkip = 0 // Number of columns to skip. Skips date/time data and unit number. Variable columnsToLoad = 0 // Number of columns to load or 0 for auto (load all columns). Variable makeTable = 1 // 1 == make a table showing new waves. LoadWave/Q/O/J/D/P=$pathName/K=0/L={0,linesToSkip,linesToLoad,columnsToSkip,columnsToLoad} /V={" ", "", 0, 1} fileName return 0 End
Is there an easy way to pass the column names (that we could get from
LastLine
using sscanf
) to LoadWave
August 10, 2015 at 08:19 pm - Permalink
