Color scales: Black out the middle range.
aqshaw
Hi
I'm making an image plot and, I'm wondering if it's possible to black out only the middle values of the range in a similarly simple way. For example if my scale runs from -10 to 10, I would like to black out a small range of values centered around 0.
Thanks
If you want them to be black, regardless of the color table, you'll need to create a color index wave from a color table. And you'll need one color index wave per image plot, because Igor uses the color index wave's X scaling to set the color min/max.
If you want to hide the pixels near 0, use a lookup wave with NaN near the middle:
July 26, 2013 at 11:16 am - Permalink
I was hoping for the pixels to "be" black. So I guess I need to make an index wave. If I'm understanding you and the relevant help file, I can copy an existing colour scheme to a wave using ColorTab2Wave. But then do I need to reset the scale of the new wave to match my desired interval using SetScale before it will work?
Thanks again
July 26, 2013 at 05:39 pm - Permalink
More info if you enter this Igor command:
July 26, 2013 at 06:25 pm - Permalink
