Clicking in Igor 7 much less... accurate?
reepingk
Also just some REALLY weird behavior in general. I was clicking "OK" when editing the above legends and suddenly the "modify trace" dialog pops up? I certainly didn't double click. It's almost the mouse click on the "Ok/Modify" button is interacting with the graphs behind it. Also is not the first time this exact thing has happened. But it doesn't happen when I try to reproduce it unfortunately.
EDIT: The same thing happened AGAIN, twice in a row. Clicking "Change" on a "Modify Annotation" dialog brought up the "modify trace" dialog. Clicking out of that (I think I hit cancel) brought up the modify dialog AGAIN. This time there was no graph behind the dialog button.
It's actually starting to get on my nerves. Can't get used to the new igor yet.
I wonder if you're using 7.04 on Windows and have a high-DPI display. If so, you might try the nightly build, which has fixed some high-DPI related issues that might cause the symptoms you described. You can use the Help->Igor Pro Nightly Build menu item to find the nightly build.
June 10, 2017 at 07:37 am - Permalink
