Cannot change graphs height in layout
I am trying to get 9 graphs in a 3x3 grid that fill one page. I cannot for the life of me figure out how to change the height of these graphs though to make them all fit. Adjusting the width is easy, I can either grad the box to make it bigger, or type in the command to adjust them to a set width. When I do the same for height, it will revert back to the same size, it will also not let me manually drag them shorter. Does anyone know how to resolve this issue?
Sounds like you have the height of the graphs set to Absolute mode. Double-click in the margin of the graph (not in the layout) to bring up the Modify Graph dialog. Check that Width and Height mode are both Auto, not Absolute (or one of the other options).
