/B flag in loadwave
I am using the following to load a single column of data and attempting to set the wave name
LoadWave/A/O/B="N=Nominal;"/J/D/K=0/L={0,21,0,3,1}
When I run this and pick the file the wave gets loaded but with the name "wave0" and not "Nominal" as expected. What is amiss?
I had used the L flag to define which column to load and the /B flag counts all the columns loaded or not.
"You can load a subset of the columns in the file using the /L flag. Even if you do this, the column info specifications that you provide via the /B flag start from the first column in the file, not from the first column to be loaded."
September 15, 2015 at 12:53 pm - Permalink
