DoWindow/F in a simple named window hook function (run command displayhelptopics "named window hook functions" for info) works nicely. In the hook function, the name of the window calling the function can be checked against the order of windows provided by the WinList function to see if the call to DoWindow/F is needed. The one limitation I've noticed is that the command line window appears to be invisible to the WinList and WinName* functions, so if the window is to be brought even in front of the command line on mouse over, DoWindow/F has to be called whenever mouse over occurs.
I haven't come across a more built-in way to do this, but I haven't looked exhaustively.
*Side note: WinName seems to return a narrower set of window types than does WinList. For example, WinName appears unable to return the names of help windows (e.g., "Advanced Topics.ihf").
Yeah, I haven't come upon a built-in setting either.
aoa wrote:
*Side note: WinList seems to return a narrower set of window types than does WinList. For example, WinName appears unable to return the names of help windows (e.g., "Advanced Topics.ihf").
You mean WinName returns a narrower set than WinList
If I come-up with a solution I will post it as a code snippet.
Help and procedure windows don't actually have names, only titles. WinList has the following note regarding this detail:
"Procedure windows and help windows don't have names. WinList returns the window title instead."
Okay so this is the quick hack I came up with: autoraising panels and graphs. Modify as you wish.
Note: if you have hooks on mousemoved event, find a different event that works. For example, I lump the hooks which do all the real work in a modified event, so these two events don't clash.
But I'm curious- this doesn't actually seem like a good idea to me. Every time the mouse happens to pass over a window it pops to the front? It's so easy to stray over territory you didn't intend that I would expect windows to be constantly popping forward.
When a panel has to be always on top, the only way to achieve this is with a floating panel (i.e. /FLT=1). So if you click (mousedown, mouseup) a control in a floating panel, the panel bubbles the event to the control, the control does whatever and transfers back to the panel, and the panel transfers the focus to the the previous panel. But a floating panel does not hook into mousewheel events. As a result if you have a setvariable control you cannot spin a setvariable control with a mousewheel when the panel is floating.
So, is this (to not intercept mousewheel events) a bug or a feature in the floating panel implementation?
Even if the panel is not instantiated as floating, the user still needs to raise the panel (i.e. the panel to acquire focus) and only then can the panel receive events, which makes sense in most cases. But in some cases, small modular panels can provide functionality without being embedded in a bigger panel or graph; thus my usecase, and thus my code.
I agree with John, particularly if you apply the hook to all open graph & panel windows and there are a lot open. How about a menu item to just add/remove the hook to/from the top graph or panel along with an option to apply to all?
By all means modify it as you see fit. The code belongs to the community.
OK, I see your point about floating panels. I would say that's a bug. I'll add it to my queue.
The present behavior of controls and the mouse wheel is an attempt to make our controls behave more like (my perhaps imperfect knowledge of) Windows behavior. In general, on Windows, you have to focus a window or panel in a window in order to get mouse wheel events. But I also note that after putting a lot of effort into that, I found that Windows 10 makes that behavior optional. Still work to be done...
April 25, 2017 at 06:50 am - Permalink
You mean
WinName
returns a narrower set thanWinList
best,
_sk
April 25, 2017 at 06:46 am - Permalink
Indeed I did mean that. I'll edit my original post to avoid confusion. Thanks for pointing that out.
April 25, 2017 at 07:25 am - Permalink
mousemoved
event, find a different event that works. For example, I lump the hooks which do all the real work in amodified
event, so these two events don't clash.Edit: updated the code.
best,
_sk
April 26, 2017 at 02:01 am - Permalink
Please enlighten me!
April 26, 2017 at 08:50 am - Permalink
/FLT=1
,mouseup
) a control in a floating panel, the panel bubbles the event to the control, the control does whatever and transfers back to the panel, and the panel transfers the focus to the the previous panel. But a floating panel does not hook intomousewheel
events. As a result if you have asetvariable
control you cannot spin a setvariable control with a mousewheel when the panel is floating.So, is this (to not intercept
mousewheel
events) a bug or a feature in the floating panel implementation?Even if the panel is not instantiated as floating, the user still needs to raise the panel (i.e. the panel to acquire focus) and only then can the panel receive events, which makes sense in most cases. But in some cases, small modular panels can provide functionality without being embedded in a bigger panel or graph; thus my usecase, and thus my code.
best,
_sk
April 27, 2017 at 01:01 am - Permalink
April 27, 2017 at 05:11 am - Permalink
best,
_sk
April 27, 2017 at 06:01 am - Permalink
April 27, 2017 at 09:04 am - Permalink
