Append the loaded waves to the top Graph
fay.tor
#pragma rtGlobals=1 // Use modern global access method. Function LoadGraph() Make/O/N=4090/D 'Decay' Display/M/W= (22,1.5,33.5,9.5); AppendToGraph 'Decay' DoWindow/F Graph0 LoadWave/O/G/W/A SetScale/I x 0,200,"ns", Decay End
PS: Is there a recommended method to learn Igor programming -_-' ?
Display
from the command line.
Now here is a function that will load a file and append to the top graph:
To learn more execute this:
First, if you have not already done it, do the Igor guided tour by choosing Help->Getting Started. This is a prerequisite.
Next read these chapters in the PDF manual:
IV-1: Working With Commands
IV-2: Programming Overview
IV-3: User-Defined Functions
IV-5: User-Defined Menus
IV-6: Interacting With The User
March 17, 2013 at 04:56 pm - Permalink
No I have not yet read the Igor's manul....
March 19, 2013 at 08:13 am - Permalink
Unless you at least go through the Guided Tour and understand Igor's "wave scaling", you will be wasting a lot of time just trying stuff that doesn't work.
Choose "Getting Started" from Igor's Help menu, start with "Introduction to Igor Pro", continue through "Waves - The Key Igor Concept". You *could* try skipping to the "User-Defined Functions" help topic, but Howard's suggested reading list is more likely to lead to success.
March 19, 2013 at 10:37 am - Permalink
March 20, 2013 at 01:23 am - Permalink
