adding parts of waves and performing fft
I would then like to add all these segments of waves coming from both parts of the original waves so that I get one wave which has all the information of all the 3.5-16.5 seconds of all the five waves and similarly for the other final wave, as a continuous wave. Then I would like to perform fft on these waves to compare the frequencies in each of the two final stitched up waves. How can I go about doing this and is this OK from a signal processing point of view?
Is it possible to write a small script to automate this as much as possible?
Another question I have is that I was trying to use the DSPPeriodogram function with the /cohr tag to measure coherence between two waves but it gave me an error saying "Wave length mismatch" . Is there a way around this?
March 1, 2013 at 10:56 am - Permalink
[/quote]
You should probably use DSPPeriodogram. The details, i.e., flags and options depend on your application.
[quote]Another question I have is that I was trying to use the DSPPeriodogram function with the /cohr tag to measure coherence between two waves but it gave me an error saying "Wave length mismatch" . Is there a way around this?[/quote]
The operation requires that both waves have the same length. For example:
but
I hope this helps,
March 1, 2013 at 11:49 am - Permalink
