Accolades to Wavemetrics for Igor Pro
I must offer my great thanks and hopefully also do a bit of promotion for Igor Pro. Perhaps even toot my own horn a bit. The link below is to a publication that demonstrates the power of Igor Pro not only to create high quality image and graphic plots but also to do non-linear regression curve fitting and image manipulation + analysis.
https://pubs.acs.org/doi/full/10.1021/acs.langmuir.4c04741
Every graphic plot and image in this publication originated within Igor Pro. To be fair, I completed the figure layouts in a macOS white-board application (Curio), with a touch of LaTeX (LaTeXiT) thrown in the mix.
It has taken many steps in what is now a 3+ decade period of using Igor to Igor Pro to make the grunt work needed behind the scenes into a matter of a happy habits. Even as I consider myself an advanced user within Igor Pro, I recognize where I've only touched the surface of what is also possible in so many other ways.
I should hope to see a few more proud moments ahead as I publish my work from using Igor Pro. The publication that I reference above is however what I might consider as the best example showing the comprehensive power of the tool across a platform of basic needs: high quality publications, robust non-linear regression curve fitting, and effective image manipulation and analysis.
Enjoy!
ps ... While it went without saying (initially), it must also be said (many times over). The support that the team at Wavemetrics has provided for me during my adventures is categorically the best.
