Accessing Traces in Scatterplot
hegedus
I have an interface with a scatterplot and intending to have the option to set the point color to a color wave via checkbox.
The interface has some traces I do not want to change and as such I wanted to cycle through the trace name list, however when I do the tracenamelist command I do not get the traces in the scatterplot.
I have used the embedded graph function for scatterplot so what is the syntax I need to programmatically set the coloring.
Figured it out but I thought I would leave a solution if some has a need in the future.
I use child window list to get the full list of windows. Now for my purposes I remove window "P0" since that is a panel that holds the controls and not any graphs. I then append the name of the subwindow to the base name and adjust the traces in that window. In this case either colored by Z or just base color.
May 23, 2023 at 10:47 am - Permalink
