Accessing numeric wave data, waveaccess sample XOP
I found substantially different results using the direct, point and storage methods of memory access.
The example had results of .031 .103 and .176 ms access times on a 2010 macbookpro 2.66 ghz I7 win7-64 machine
My results were --------- .376 .377 and .386 ms access times on a 2011 lenovo m91p 3.33 ghz i5 win7-64 machine
IGOR pro 32 6.3.2.3
Compiling as release vs debug had little effect. VS12 express
So...why the 10x difference on direct memory access?
I checked debugging and it was off
I had virus scan disabled
I had internet port disabled.
Is there something incorrect in my installation which is hobbling IGORPRO? Or is this an issue with running on Lenovo machines instead of MACs?
data
•Make/N=(50,50,50) wave3D
•Variable timerRefNum
----waveaccess.xop compiled with debug---
•timerRefNum = StartMSTimer
•WAFill3DWaveDirectMethod(wave3D)
•Print StopMSTimer(timerRefNum)/1e6
0.37694
•WAFill3DWavePointMethod(wave3D)
0.377144
•WAFill3DWaveStorageMethod(wave3D)
0.386606
----waveaccess.xop compiled with release---
0.376838
0.377077
0.386917
Ref from xop manual
Speed Comparisons
The WaveAccess sample XOP implements routines that fill a 3D wave using each of the wave access
methods described above. To try them, compile the WaveAccess XOP and install it in the Igor Extensions
folder. Launch Igor Pro and execute the following commands:
// Enter the next three lines as one command line
Repeat replacing WAFill3DWaveDirectMethod with WAFill3DWavePointMethod and
WAFill3DWaveStorageMethod.
The following times were recorded for filling a 200x200x200 double-precision wave using the release build
of WaveAccess. All tests were run on a 2010-vintage MacBook Pro with an Intel i7 laptop processor running
at 2.66GHz
Operating System Direct Access Temp Storage Point Access
Mac OS X 10.6.3 0.018 s 0.086 s 0.214 s
Windows 7/64 0.031 0.103 0.176
Windows 7/64 Under VMWave Fusion 0.037 0.124 0.181
// Enter the next three lines as one command lineInstead you executed the commands one-at-a-time in the command line. This means you were timing how long it took you to type and execute the WAFill3DWaveDirectMethod command, not how long it took to execute it.
Execute it like this:
Better yet would be to put it into a function:
Since functions are compiled it does not matter if you put the commands in one line or multiple lines.
July 17, 2013 at 09:23 am - Permalink
Lenovo M91p I5 3.33 ghz win7-64 igor 6.3.2.3
Direct = 34.9ms, Point = 40.2ms, Storage=37.5ms
XOP manual pg 160 lists results on a 2010 mac I7 2.66 ghz win7-64
Direct = 31ms, Point 176ms, Storage=86ms
Access time improves dramatically if run 10,000X in a recursive function to remove "print" overhead timing, John Weeks' suggestion.
Direct = 0.080ms, Point = 2.47ms, Storage=0.541ms
...and on a Mac?
Function with 10k recursion
Output
•testdirect()
direct sec= 7.97278e-05 , point sec= 0.00246937 , memory sec= 0.000541131
•testdirect()
direct sec= 7.91245e-05 , point sec= 0.00247078 , memory sec= 0.000541233
Function testDirect()
Make/O /N=(50,50,50) wave3D
Variable timerRefNum1
Variable timerRefNum2
Variable timerRefNum3
Variable i, j1, j2, j3
timerRefNum1 = StartMSTimer
for (i = 0; i < 1e4; i += 1)
j1=StopMSTimer(timerRefNum1)/(1e10)
i = 0
timerRefNum2 = StartMSTimer
j2=StopMSTimer(timerRefNum2)/(1e10)
i = 0
timerRefNum3 = StartMSTimer
j3=StopMSTimer(timerRefNum3)/(1e10)
Print "direct sec= ",j1,", point sec= ",j2,", memory sec= ",j3
July 17, 2013 at 11:48 am - Permalink
