Accessing data folder structure from PXP file
rhjpires
Quick question: is there a way to read data from a PXP file without either opening it in IGOR, nor actually loading it into a working experiment file? For example, I would like to set up a variable which is dependent on the number of datafolders inside different PXP file which I want to access via the
LoadData
operation.Bottom line, my question is general: Is it possible to read and operate on closed PXP files without opening them, nor loading their contents into a working experiment, while using some elements of its contents as input parameters?
Thanks in advance,
R.
You can load data folders without loading their contents. Here is an example:
March 4, 2018 at 09:55 am - Permalink
