3D volume calculation
sjr51
ConvexHull
on my tripletwave (x,y,z coords). I have M_Hull and can visualise it in the Gizmo, but I am stuck as to how to get out a volume for it. Any help appreciated. Maybe there is a much simpler way to do this, that I am missing?
To plot this data use:
If you inspect the wave M_TetraPath you will see that it contains triangle vertices separated by NaN rows. In each triangle the last vertex repeats the first in order to close the path for drawing. If you collect every 4 consecutive triangles you have a full tetrahedron.
Given the list of tetrahedra, you can compute the volume by summing the individual volumes of all the tetrahedra because by definition, the triangulation decomposes the volume into non-overlapping tetrahedra. One way to compute the volume of an arbitrary tetrahedron is using Igor's function MatrixDet(waveT)/6 where waveT is a 2D wave constructed from the vertices of the tetrahedron as follows:
Make/O/N=(4,4) waveT={{x1,x2,x3,x4},{y1,y2,y3,y4},{z1,z2,z3,z4},{1,1,1,1}}
for a matrix of the form:
x1,y1,z1,1
x2,y2,z2,1
x3,y3,z3,1
x4,y4,z4,1
I hope this helps,
Note: in IP7 (after the nightly build) you can get the result directly using the commands:
February 15, 2016 at 10:04 am - Permalink
The new flag in the nightly build works great.
Edit: deleted my comment about timing since this referred to my own procedure and isn't of interest to anyone else.
February 16, 2016 at 11:15 am - Permalink
