3D scatter plot
As i am dealing with point cloud data, i am looking for a way to read point information in the Gizmo 3D scatter plot. For instance in a normal graph, igor allows to pull down this information menu with two cursors, is there a way to do the same with a Gizmo 3D scatter plot?
Thanks
Simon
Gizmo does not support a 3D cursor mostly because real 3D input devices are not very common. You can however use the poor-man's approach which is to create a new wave e.g.,
and append this wave as a new scatter object using a distinctive marker (in practice you may want to replace the zero setting with a point somewhere inside the volume occupied by your original scatter). Next add a panel with controls that let you modify the position of this "cursor" marker, for example:
If you do have access to a 3D input device you can connect it to the XYZ value of the wave and bypass the panel.
I hope this helps,
June 2, 2011 at 12:02 pm - Permalink
This method work well.
But it will be time consuming for what i need to do. i am working on an alternative method.
Thanks a lot
Simon
June 2, 2011 at 12:38 pm - Permalink
I used this info to plot a 3D plot for aircraft data (long, lat, alt). It works very well but I would like to colour the points by a data wave.
Could you tell me the best way to do this.
Thanks
December 1, 2016 at 12:24 am - Permalink
It would be best if you started a separate thread for this question.
It is not obvious from your question if you are plotting a path or a scatter object. In both cases the coloring is accomplished in a similar way: you use your data wave to create an appropriate color wave. The general approach is to use one of the built-in color tables to construct a color wave that is appropriate for a path or scatter object. You can do this in a few command lines or take the following shortcut:
1. copy your source wave that defines the locations of the data:
2. set the z-column to your "data wave":
3. use the following command line to generate a color wave:
4. use the created tmpSrc_C as the color wave for the path or scatter object.
I hope this helps,
December 2, 2016 at 07:26 am - Permalink
